On the sides of the head, near the back.
On the sides of the head, near the back.Was driving my car and it just shut off and won't start back up and will crank. I pulled this code from the car and was wondering where the Camshaft position sensor is because it clearly crapped out on me.
Is the starter clicking when you try to crank it?So I just replaced it and have no more engine code but the car still won't start.
Check fuses?Yes it is.
It could be that you just have a bad battery. try to turning off the climate fan and leave the headlights off and get a jumpstart.Ok I will give it a shot. The battery keeps dying because I haven't been able to run the car and it's below zero here in Chicago. I'll disconnect it completely for an hour and give it a shot. Thanks!
The battery is good. I disconnected it and waited for it to reset the ECU. This didn't work. I checked the plug for the camshaft position sensor and the voltage is correct.It could be that you just have a bad battery. try to turning off the climate fan and leave the headlights off and get a jumpstart.Ok I will give it a shot. The battery keeps dying because I haven't been able to run the car and it's below zero here in Chicago. I'll disconnect it completely for an hour and give it a shot. Thanks!
