hi! so i got a p2261 code on my 2011 Gen Coupe. At first, I didn't know what that is so i took it to the dealer. he eventually change my turbo/wastegate. Nothing has changed, my turbo boost normally for about 5min until it cut the boost to approx 3lbs. i have a hks blow off valve, but I always had it since the beginning and no worries before. No boost leak, my wastegate is not leaking either, and I've test the solenoid outside the car and seems to be working fine. Ive seen a thread where you bypass the solenoid, but that didn't work, still have the code. What could possibly be the problem? all the thing i could look at or change is changed (except for the solenoid itself since it worked fine when i tested it). would a tune would clear it? could it possibly be a bad wirering? please help me my car has not run correctly for a while now😥
