1 - 5 of 5 Posts
P2261 CEL Code? Help!
The car at times sounds like its dumping air when I start boosting but not all the time. I don't have a BOV but I do have the Torque solutions sound plate installed to vent the air when I let off the gas, been running it for 2 years with no issue. All the vacuum lines and hoses are tight and nothing sounds like its leaking. Could the BPV solenoid be malfunctioning? I ordered a new one after reading some threads on here... its looking like that's the culprit. I know you can bypass it but I don't have a BOV
Member
Can you take off the plate to see if the problem is still there?
If I recall, the OEM blow off valve isn't that durable, so maybe it's just failing? IDK. Hopefully someone else chimes in.
1 - 5 of 5 Posts
