1 - 7 of 7 Posts
So, I just picked up a PA reflash module from another member, I still need to get it unlocked for my car, and I was curious about weather or not hard intake pipes such as the AEM set require custom tuning? The Beyond Redline site says their canned tunes are compatible with intake and exhaust, but don't mention intercooler piping. I wouldn't think that a custom tune would be required, but figured I would check.
Anybody have experience with this?
Thanks!
Pm tim, he'll help you out. My guess is depending on what pipes and depending on how the map sensor bung is located. But ie say with injen pipes? You dont need a new tune. Wouldnt hurt to quickly get dynoed after install to check your a/f ratios
Lord Stig
I'll tell you right now. After speaking with BR about their Stage 3 tune and using my FMIC. They said it might work unless if I was running the AEM FMIC, then I'll have some issues. I guess there's an issue of how the sensor is placed on the TB side. So you will need to go custome tune. There's a local member over here in he west cost that had this issue and went to get custom tuned due to hs AEM FMIC.
I have the same issue with the Injen pipes and the BR PA. The bung for the MAP is not angled, however BR sells a bung that you weld to your pipe and corrects it.
Guys check out my build thread and the bong i replaced. It was a $30 job at a local machine shop and took them 1 hour
Cx racings bung was dead flat and about 1/2 thick/tall
1 - 7 of 7 Posts
