As of about 30 minutes ago, I cannot lock or unlock the passenger door from my fob. I cannot unlock it with either inside or outside door lock buttons. I must pull the inside handle to open the door. I will correct this and say that I can lock it from the fob and the door lock buttons on the inside of the door. When I lock the door from the fob and the door lock button it makes a hideous squealing noise almost like a cable unwinding. The window opens and closes OK so it's all in the lock assembly. Any ideas? The car has 139,650 miles on it and it worked fine this morning. Now...not! I checked Red Raspberry's post and changed the 10amp door lock fuse, but that does not help. The whole thing sounds like a gear wheel has teeth missing on the RH door lock when locking it. I can open the door from inside by overriding the lock and just opening the inside handle. When it gets locked back that's when I get the loud noise.
