1 - 5 of 5 Posts
Just got a 1.5 canned tune with Korean popcorn, I own a 2.0 and the crackled are extremely loud and it happens too much. My bk2 is currently straight piped. If I add a performance exhaust on it, will it still happen as much and would it be as loud?
Member
It will happen just as much, but it might not be as loud.
I thought that it only happened if you held the gas pedal slightly while slowing down? Does it just happen all the time?
How often does happen? I was planning on getting it but I also don't want my car popping 24/7.
I think it only happens between certain RPM ranges 3-4k if I remember correctly but I personally wouldn't get it for that exact reason you said. I bet it can get annoying after awhile...
it only happens when you barely squeeze the gas open anywhere between 3k-5k rpm. other than that it won’t pop
1 - 5 of 5 Posts
