A coupe days ago I installed some BC BR coilovers. After about a day of driving I noticed a clicking or popping noise that kind of sounded like the when you run over an acorn or rock. Like just a pop. Its coming from the rear and I think it’s just the driver side but I’m not sure. I’ve looked around and some of the answers I’ve seen have been improper spring preload, loose bolts, or a problem with the end links. I know how to look for improper preload of the spring or for a loose bolt but my question is what would I need to look for to see if it’s a problem with the end links? I will note that during installation I had trouble getting the end links to line back up with their proper hole, and I had to push down on the entire rear suspension in order to get the holes to line up, then I had to tap it in. Could that have contributed to the problem? Any help is appreciated, whether you may have an idea about why the suspension pops or help with my questions on the end links.
