Hello!
Longtime lurker here. I was hoping you may be able to help. I'm concerned my head gasket may be leaking on my 2013 3.8l. I had my check engine light come on yesterday and had it checked. They saw multiple misfires for cylinders 4 and 6, which I assume are next to each other.
When I start it, it does occasionally run rough for 5-10 seconds then smooth out. It's 30 degrees here though, so I figured she was just cold.
I noticed yesterday that my oil looked good. Not milky, but maybe a tad high. (Not sure, haven't checked it since it was recently changed) but my coolant was low. There was some in the bottle, but not much. I topped it off.
If I'm leaking coolant into cylinders 4 and 6, that would explain the rough running / misfires after sitting a day and the low coolant.
OTOH, maybe I just need new plugs and have a coolant leak somewhere. I just hit 30K miles. I heard they're good for about 40K.
I thought maybe I'd pull those plugs and let it sit for a day and see if I see some coolant in the cylinders with my cheap USB borescope. Any other ideas? Are the plugs easy enough to access on a 2013 3.8?
I appreciate any advice you may have!
Thanks!
Thanks!
