Bump. No one has any ideas on this?
Yea my car sat for about 2 months before Christmas and it was fine. I got up to about 50mph the other and then hit the brakes fairly hard to see if it was rust but it's exactly the same after doing it.Just guesses but maybe the power steering system needed to be primed after sitting for so long although my GC has sat for longer periods and I've never experienced that.
As for the brakes maybe they built up a decent rust spot on the rotor in a single location? I've had that happen before but it usually goes away after some good braking or a few miles.
Well thanks for your help. I'll get the brakes checked out after the snow here goes away.Oh, sorry. I didn't mean that the power steering system needed to be primed by someone. I just meant maybe the oil had drained back after sitting for a while and it needed to circulate for a while to get back to normal.
But if it's still feeling this way and the brakes are still causing a wobble in the steering wheel then I'm not sure what it could be for either of them.
Maybe your rotors are warped? Or maybe they have brake fluid on them or.....I'm just not sure.![]()
I park outside most of the time.Usually wheels go on at around 90 ft-lbs but it depends on your rims since some rims may crack at high torque levels. Make sure they are the same torque all the way around though.
By chance, do you park your car in the garage or outside? What you are describing is a symptom of ice frozen to the inside of rims, causing unbalancing and shaking at certain speeds.
You know I don't think I've ever checked the p/s fluid level. I'm not near my car so I can't check anything now.Brake wobble is probably warped rotors.
Steering... possibly the fluid braking down. Hows the level of the p/s fluid?
