Super Moderator
When you say you "can't make posts" what do you mean? Please describe what is not happening for you.
Super Moderator
Make sure you preview the post before posting it to make sure your picture links are working properly. You won't be able to edit the post once you submit it until after it is approved.
I've set up 4 Vbulletin boards in the past, know how to use it very well. :)
It was a permissions issue that was resolved.
Administrator
Hi,
I looked at your permissions and you should have permission to post in the classifieds. If you tried to post right when you hit 50, there is a lag between when the system syncs up and that is probably why you could not post. You should be all set now to try and start a thread. Can you please clear your cache and try again. Let us know if it is still not allowing you to do so.
~Sheena
