Nicely done man.
I always thought I had to purchase both the front fascia and lip to make it look like your after shot. But I guess the lip pretty much includes the fascia. What was the original paint when you received it? Is this the poly or fiberglass?
I heard fiberglass doesn't need any screws/tapes to be attached, not sure if painting would be any different.
Also not sure if I should get the fiberglass or poly
Seems like nearly everyone has the Prodigy version and not the Sequence, which are pretty similar.
Sequence Spec-1 Front Lip, importshark.com
I appreciate the touchup website
I didnt think there was a creamy white and only the kraussel white
And what grade did you happen to use for the scruff pads?
This would be so much easier if these parts were already painted before being shipped, I'm guessing all the lips from prodigy and sequence aren't painted eh? I would like to paint the bottom middle black so i'm guessing 1 can should be enough. You think it was necessary to paint the inside of the lip as well since it's being attached to the bumper?
