Just 2 days ago my car radio stays on NO MATTER WHAT. I take my key out of the ignition and turn close the door it's still on. It was never like this the years I have had it.
I've pulled the fuse, disconnected the battery...I don't know what else to do. This problem is killing my battery. If anybody has ANY advice I'd appreciate it.
Member
Do your USB/Power ports still work when you pull out the key?
Maybe the ignition switch is not working properly and not switching off the accessory power.
Yes all of them still work. Would that also explain why my remote won't lock or unlock my car doors? Thank you...if so is it difficult to swap the ignition switch?
Yes I have 2 amps, one for my sub & one for my speakers. I've had them for years though and never have I had a problem.
Factory headunit? If not are you running line out convertors? Maybe one of the amps is drawing off a constant power lead? say for turn on power?
