1 - 5 of 5 Posts
2011 2.0t: My radio display is not showing any info (track, radio station, mode). I looked on here and have not found anything to solve the problem. I already checked memory and audio fuses and both are good. I also already tried disconnecting the battery to reset the radio and I am pretty sure it didnt reset because it remembered my blutooth. Does anyone know a solution to this or maybe a way to reset the radio?
Just pull a used one out of a wrecked Genesis at a junk yard. At least that's what I would do. I do know if you can still take her to the dealer and get a replacement that way.
Did you pull the yellow fuse when the battery was connected?
On my Accent one time the radio would not shut off. I disconnected the battery but that did not help. I pulled the memory fuse while the battery was connected and that fixed the problem.
UPDATE: I replaced it with another screen lol and it worked. Not sure how I messed the first one up but thanks for the help!
1 - 5 of 5 Posts
