Hey guys I’m kinda new at this and I’m learning as I go. I want to have my care risen about half n inch, but would I need spacers in order to do so? Again I’m new at this so anything would help
You would think so? I have 20’s on a g35 lolEasier thing to do is get taller tires.
When you just put spacers to adjust height, you change the toe, camber, and caster.You'd probably want to have some type of spacers custom machined to move the struts 1/2" from the body for the extra clearance. Mabey this guy can help.
Yes thats true, for a half inch I like your idea of achieving that with tire/rim sizes.When you just put spacers to adjust height, you change the toe, camber, and caster.
Positive toe
Positive camber
Less negative caster.
This is the reason why I said it would be easier to just get taller tires.
When the suspension compressed, these geometries change, the opposite is also true
