For those of you developing rough cold start idle, I think I've found the cause.
leaking injector(s)
to test:
start the car to verify rough idle
turn off the car
pull injector fuse on passenger side in the engine bay
start the car once
If it catches and dies, put the fuse back in and start it up.
The car should idle normally.
with as many miles as the first gens are getting now, it doesn't surprise me.
A good injector cleaning should fix it. The injector cleaning additives don't do much in this case, but worth trying once.
I tested the injectors on the bench with 2 AA batteries to see if there was some odd firing. 2 of mine had dull clicking.
I ran injector cleaning solvent through mine on the bench, then ultrasonic cleaned them and ran cleaner through them again.
Firing like a champ.
leaking injector(s)
to test:
turn off the car
start the car once
