21 - 23 of 23 Posts
I bought a $10 threadless shift knob adapter off eBay and it works great. Took about 5 minutes to install and it hasn't budged in over a year.
Yes - I just did. I bought a Mishimoto pistol grip and pulled the OEM shift knob today only to find out my 2015 R-spec has the evil fork-type shift shaft. I borrowed an M12x1.25 die from my friendly local machine shop and threaded the shaft. Turned out pretty well (see pics). I was surprised to find out there is a 3 lb weight attached to bottom of the shift lever - it's the black mass in the pic and is attached with 3 bolts. Note the odd shape, with the center of mass on the driver's side.. Is this a counterweight to help shifting? Can anyone comment about pros/cons of removing it?
Helps get into the rev gate easier? On my BK1 you have to hit it to the left before going into Rev.
I'm going to get that adapter! Can you please explain how you removed the stock knob though? I can't get it off to save my life!!
21 - 23 of 23 Posts
