2015 3.8 ultimate 6 speed. 16,000 miles,in 5th and 6rh at 3300 rpm or more, the shifter has a slight rattle, hold onto the shifter it goes away. Is it the trans mount, or shift linkage bushings? OR?
If you remove the shift knob there’s a little metal piece right under it. That’s what rattles. Took mine apart and found that annoying garbage!
Trust me, just go ahead and throw a short shifter in there. I have the same model and it was a pain to always have it rattle, and since 2014+ has a Y fork instead of threaded knob, getting a new knob was out of the question. Garageline has the cheapest STS which is what I have. Best modification I’ve made so far lol
Change the shifter knob to a screw on type problem solved.
