I have searched, but I have not found a clear answer. People have installed/swapped these items to help fix/improve some of the problems they have been experiencing with their manual transmissions. The combination resolves the issues for some and helps others. That much I have gathered.
What about the people out there that have tried the above and have had no luck. Did they void the warranty on their transmissions with these mods (BTW, I have read several depends on the dealer/any mod can posts)?
I don't see why/how new and improved front bushings and the correct amount/grade of gear oil could or would void the warranty. If I had to guess, I would say that those two items would go unnoticed? The Short Throw Shifter, however, is hard to miss. That, and that It does modify the action of the shifting mechanism connected to the manual transmission.
I am considering all three mods. However, I am not doing it to "fix" anything. I just want a better driving experience. From what I have read here, it does deliver that (among other things).
In short, is the Short Throw Shifter one of those things that needs to be swapped out with the OEM shifter before going to a dealership?
I know that the answer for this MAY be a no brainer (for transmission work), but what about unrelated work?
