1 - 20 of 34 Posts
I'm changing my plugs in gen coupe 2.0t. Does anyone know how many ft/lbs of torque I should tighten them too. I checked all data but it doesn't say. Thanks
GT30Rspec
I use the German specs... GoodNTight.. :)
depends on the plug(washer/gasket).. tighten till it stops..then maybe a 1/4 turn after that.. they are pretty long.. not gonna fall out.. :)
what plugs you puttin in??
derp.
15 - 22 lbs/ft..Theres a thread somewhere here with everything you need to know about plugs
derp.
From what ive read you should gap at .031 if you up the boost. Im at stage2 with stock gap and i have blowout. Im changing plugs later this week gaped at .031
GT30Rspec
I am running upwards of 25psi till redline without a problem...
Try and see what works best for you.. takes 5 minutes to swap the plugs..
derp.
What is your gap?. i havent checked mine so i have no idea what mine is but BBB told me to just swap and gap at .031
Just so u guys know if ur looking for ngk plugs go to advanced or autozone...the part number is 6619...they wont come up if they look up the car though...odd....they r like $8.50 each plus it beats waiting for them to come in online
SUN★WORKS
^^ this is exactly what i do.
SUN★WORKS
My car doesnt run right with anything gapped over .028
SUN★WORKS
Severed member
I checked my NGKs before I put them in; and low and behold they were gapped at .041. that is too large if you are tuned...
I encourage you to get a tool, and check them BEFORE they go in...
SUN★WORKS
So I had one step colder NGKs gapped at .032 and couldn't go past 5.5k without it popping and blowing out. Lol
Gapped them down to .028 and all is good.
1 - 20 of 34 Posts
