1 - 5 of 5 Posts
Hey guys I’m having issues with my clutch and I need to replace it, I can’t find a decent priced stock clutch anywhere. I found a stage one spec clutch kit that I can afford but was curious if I need to change anything to go stage 1? I would like to be able to just replace the clutch and not have to do anything else but if I do any ideas what else I would have to change?
on this car, when you change the clutch, always change out the throw out bearing.
Reader of many threads
SPEC's clutch kits require their aftermarket flywheel as well. Most kits do NOT work with the stock dual mass flywheel in the coupe.
From Spec's site:
These clutch kits fit our flywheel only. However, the flywheel will accomodate the factory clutch or SPEC clutch. The SY38S is a lightweight, single-piece billet alloy steel.
1 - 5 of 5 Posts
