1 - 5 of 5 Posts
vr-4 convert
I got a nail in the INNER sidewall couple days ago :mad: and needed to get it replaced today. Unfortunately they didnt have the same tread as the stock 19"s and I ended up getting dunlop direzza 245/40R19 94W put on the passenger rear.
http://www.discounttire.com/dtcs/fi...yr=2010&pc=29363&cf=false&vid=017088&sw=false
im planning on replacing it to the correct tread asap, but how bad is this for my tc, tranny, lsd, and how dangerous is this for rain? ( i know its not optimal)
http://www.discounttire.com/dtcs/fi...yr=2010&pc=25957&cf=false&vid=017088&sw=false
wow! $314 for oem tires.
hankook v12
http://www.discounttiredirect.com/d...c=11399&counter=6&ar=40&rd=19&sw=false&cs=225
would it be ok to replace just the two rears with these? i have 12k with light to mid driving.
Seeing as how you already have a brand new dunlop on the rear, just get another one for the other side. It's not going to cause any problems having 2 different makes of tires on the car, front and back.
oh hayyy
Yeah, as long as you match up across the same axle you're all set.
As stated, you want the same tread diameter on the rear both sides. If you put 500+ miles on the new tire then buy a new tire for the other side, you're basically driving in a perpetual circle with one tire spinning faster than the other. Long term it's not good on your diff.
1 - 5 of 5 Posts
