1 - 1 of 1 Posts
Thought I'd share something interesting. Recently installed my D1 Factory drift coilovers and got an alignment done a couple days ago. Appears that from factory settings, the toe has been off so that on all 4 wheels, the outer edge of the tire has been degrading substantially. Most logical reason is the toe of each tire has been pointing inward, causing the outer edges of the tires to wear. Now after my alignment, and cambered with the coils, hopefully it'll even the wear on my stock tires. Just recently hit 10k miles so got a few more to go, however the car does sway a little bit and time to time due to the imbalance.
Anyways just some food for thought and I'd advise you guys and gals to just check the outer and inner edge of your wheels just in case. Maybe you can get them replaced under warranty? :)
1 - 1 of 1 Posts
