1 - 1 of 1 Posts
On the rear front of the car I was tightening the 2 bolts that hold the plate in place and the bolt threads are fine but the inside got stripped. The other bolt where you loosen the nut to get the plate off is fine but the actual bolt you remove will not tighten. I ran across another post where someone snapped the bolt where you loosen and tighten the nut and the comments made it seem like it wasn't a big concern but I thought I'd ask around to see if it is crucial for this to be fixed before driving the car.
1 - 1 of 1 Posts
