1 - 2 of 2 Posts
So I just ordered ARK test pipes and bought an ISR axle back from someone. I was going to leave the stock down pipes. My question is will the test pipes set off any lights on my dash and will the axle back fit my stock down pipes. I looked at other down pipes n this one is different but is made for my car.
2013 3.8 Track White Pearl
No the test pipes will not cause a CEL.
I assume you are a 3.8? An axle back does not connect to your downpipes, the stock exhaust system goes like this on the 3.8: exhaust manifolds > downpipes > secondary cats > midpipe > axleback. The test pipes replace the secondary cats, the axleback should be self-explanatory at this point. But, ISR does not make an axleback so I believe you mean it's a catback which would replace the midpipe and the axleback sections, and yes it will bolt right up.
1 - 2 of 2 Posts
