41 - 60 of 360 Posts
If you ever noticed you can use you fob to lock your car and your key to unlock it and the alam will not go off, try that with any GM and the alarm will go off ;)
You can open both doors with your key in the right door at the same time, on the left you can twist the key twice to open the left then the right.
Opening the trunk will not set off the alarm. Sneezing near a GM will set off the alarm.
LivingADream
As soon as you turn the key in the ignition, fireballs of hot air below at you. This happens even if you have the fan and AC on before starting the car.
Edit:
What I meant to say is after driving awhile and the AC is chill, if you rev it over 5k or something for a good minute or longer, you will feel hot fireballs of air come onto your face from the vents.
Edit:
in other words blow your motor up reving it up at 5k forr about a min looooool. not sure if i like fireballls ;) but great info to know! ;)
LivingADream
I don't think it even takes that much effort. Maybe more like 3k. Whenever I try to go from 0-40 MPH as fast as I can, I get fireballs in my face. Even when my car isn't hot at all. Maybe it's time to get oil change but I'm only at like 2K miles on my odometer.
I didn't know a naturally aspirated Civic Si would be able to give the 2.0T a run for it's money. Does that count?
06+ SI will beat 2.0 stock for stock
Edit:
That's because the AC clutch is disengaged under certain load/rpm points.
Sometimes your trunk will open misteriously with out your using the fob or the unlock button on the door :dunno:
This happens to me too, although I've convinced myself that I'm just hitting the trunk open button on my keyfob when i lay down or something, at least I hope :dunno:
Yup the control programmers were smart enough to know that if you had it floored,or close to it, you wanted maximum power available to you so the A/C compressor automatically disengages and then reengages when you cut back on the gas.
Ex-DSMer
This is the most valuable thing I've read on GenCoupe. I'm old-school and still practiced turning off the AC before romping on the car. :)
Pretty much common for the last ten years or so.
2013 is a whole diff ball game. Your making 50 more whp then us
You should not have any issues at all, especially with your mods.... I could careless about beating Si, most of these guys can't drive anyway. I'm all about being able to compete with EVOs and Z's. Upgraded turbo, intercooler, injectors, and a few other things - Here I come!
2012 Gen. 3.8 Track w/ZF
:rofl:I don't know if anyone has noticed, but the GCs all have a weeny sounding horn!
