41 - 48 of 48 Posts
I have 225/50 17 in for front and 225/55 17 in rear Blizzacks no problems
Advenio Pariter
That sounds like a good choice and it keeps your TCS happy too.
Hi. Actually, the details are in my garage. I went with a square setup of 215/55 R17 on Momo winter rims. Everything under $1k. I opted for the thinner tire so that I would get more pressure on the road in snow (P=F/A). The thin tires in the back make my tail a bit happy so to speak. Since I plod along on back roads during my commute the sensitive ECS is not a big problem. Next time I would likely do either 225 square or 215/225 staggered. This is a daily driver so regardless of road conditions I drive it. Winter tires make a huge difference in safety and handling.
BTW, born and raised in Western Washington.
I am Eastern Washington and also drive regardless of road conditions. I am not so worried about driving in the snow as I am making the car more dangerous to drive with a square setup with smaller rear tires. :p Too bad I can't fit 17's with the Brembos! Thanks for your response. I am still holding out hope to hear a response from those who say they've run square 225/40-19 winter tires.
Reader of many threads
Narrower tires = Better in snow regardless of TCS working properly or not... your setup would probably carve through deep snow better than my fatter 18" setup :)
My neighbor runs on 305/30/19 winter tread on his 911 Turbo stock rims and he is able to get through nastier stuff than me (all hail AWD!)
@ conedamage why not 225/40 19in.. front and 225/45 19in. rear
I would have done that had I really thought hard about it...but when I found someone selling a brand new set if Blizzaks that normally cost $1,100+ for $600 I jumped on it. That's how I ended up with square 225/40-19. :p
Just thought I would post an update for anyone else who may wonder the same thing as me: PepBoys mounted up my square 225/40-19 Bridgestone Blizzak LM-60 snow tires for me. They work great! The speedo is off by just 1 or 2 mph at most speeds, or approximately 2.3% verified by GPS.
I drove my car home 2,400 miles through some pretty nasty weather and did just fine. Traction control slaps my hands frequently if I step on it, but it works just fine with normal driving and if I turn off traction control; this seems consistent with what others have said.
Additionally, if you check the tire size and they are in their right places, please provide the following info to better assist us to help you:
Year/Engine/Tranny/Trim Level
Brand/Model of Tire Purchased and put on car
One thing I know is that new tires sometimes have a gloss of sheen to them that needs to wear off. While on the tire, it can make it slicker against the road surface causing TCS issues for a few other people that I have seen.
41 - 48 of 48 Posts
