1 - 1 of 1 Posts
Hello, I know there are other threads partly explaining this but I couldn’t find enough information. I’m installing a bolt on Garret turbo from ATP. First step is to remove manifold/turbo. I can’t do so because the power steering pump is in the way of the last bolt on the manifold. Take off the pump then, I tried and the 2 bolts holding it into the block arnt able to come out. I attached some pictures. Trying to do this in 3 days, anything helps, thanks.
75111
75112
1 - 1 of 1 Posts
