"While some turbochargers sacrifice smooth drivability with high operating boost pressures in the 20 psi range, Genesis Coupe uses a refined, low-boost calibration for smoothness and efficiency," said Derek Joyce, Genesis Coupe product manager. "We could have opted solely for big performance numbers, but our focus for the 2.0T was a more balanced package."
GENESIS COUPE PRODUCT HIGHLIGHTS
With the start of U.S. market production now just a few months away, Hyundai Motor America is releasing model configuration and color choices for the 2010 Hyundai Genesis Coupe.
"Genesis sedan has set a new benchmark for the $35,000-$40,000 premium sedan, and we think Genesis Coupe will do the same in the sport coupe segment," Krafcik said. "From our 30-mpg 2.0T with its low-pressure intercooled 4-cylinder turbo, to the 3.8 Track model with an estimated 310-hp and Brembo braking system, Genesis Coupe offers a wide range of powertrain and performance choices for driving enthusiasts of all stripes."
There are seven basic Genesis Coupe configurations:
- 2.0T
- 2.0T Premium
- 2.0T Track (6-speed manual transmission only)
- 2.0T R-Spec (late availability, 6-speed manual transmission only)
- 3.8
- 3.8 Grand Touring
- 3.8 Track
GENESIS COUPE 2.0T: A MORE EFFICIENT TAKE ON THE REAR-WHEEL DRIVE SPORT COUPE
Standard equipment includes:
- 2.0-liter, low-pressure, turbocharged, intercooled 4-cylinder engine with dual continuously variable valve timing delivering an estimated 210-hp (regular), estimated 220 hp (premium), an estimated 223 ft-lbs of torque (at just 2,000 rpm), an estimated 30 mpg EPA highway rating and an estimated top speed of 137 mph
- M6VR1 6-speed manual transmission (Optional: A5SR1 5-speed electronic automatic transmission with lockup torque converter and steering wheel-mounted paddle-shift Shiftronic controls)
- 18-inch Euroflange alloy wheels with staggered Bridgestone Potenza RE92A tires (P225/45VR18 front, P245/45VR18 rear)
- Electronic Stability Control with ABS, Electronic Brake-Force Distribution and Brake Assist
- 12.6-inch ventilated front rotors with 60mm single piston floating caliper
- 12.4-inch solid rear rotors with 43mm single piston floating caliper
- Sport-tuned MacPherson strut dual-link front suspension and five-link rear independent suspension, 24mm front stabilizer bar, 19mm rear stabilizer bar
- Strut brace
- Quick-ratio hydraulic steering (2.7 turns lock-to-lock)
- Tire Pressure Monitoring System
- Front, side, side air curtain air bags
- Active front head restraints
- Driver’s lumbar support
- Black-out front lower fascia
- Trip computer
- Air conditioning
- Satin silver and chrome interior accents
- Keyless entry system
- Leather-wrapped steering wheel and shift knob
- Power windows (one-touch up and down), door locks and mirrors
- AM/FM/XM/CD audio system with six speakers
- USB/iPod/Aux jack connectivity
- Steering wheel audio controls
- Cruise control
- Projector beam headlamps with auto light control
- Integrated Bluetooth including steering wheel controls
- Temporary spare with steel wheel (T135/90D17)
The 2.0T Premium model adds or substitutes:
- Power driver seat
- 360-watt AM/FM/XM/CD-changer Infinity premium audio system with 10 speakers including DVC subwoofer, eight-channel external amplifier, and diversity antenna
- Smart Key with push-button start
- Electrochromic mirror with HomeLink and compass
- Sunroof
- Navigation system (mid-year availability)
The factory-tuned 2.0T Track model builds from the 2.0T Premium, adding/substituting:
- 19-inch Euroflange gunmetal finish alloy wheels with staggered high-performance summer-compound Bridgestone Potenza RE050A tires (P225/40YR19 front, P245/40YR19 rear)
- Unique Brembo braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red)
- Unique track-tuned suspension, higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, strut brace
- Torsen-type limited-slip differential
- Black leather bolster seats with high-friction red cloth insert
- Aluminum pedals
- Aero windshield wipers
- Rear spoiler
- Xenon HID headlamps
- Fog lamps
- Lightweight temporary spare with aluminum wheel (T135/80D18)
- Note: Automatic transmission not available with 2.0T Track
Later in the model year, a tuner-focused performance model, R-Spec, will arrive at Hyundai dealerships. Genesis Coupe R-Spec is meant to be the ultimate upgradeable, affordable, turbocharged rear-wheel drive performance platform. R-Spec equipment includes:
- 2.0-liter low-pressure turbocharged intercooled four-cylinder engine with dual continuously variable valve timing delivering an estimated 210-hp (regular), estimated 220-hp (premium), an estimated 30 mpg EPA highway rating and an estimated top speed of 137 mph
- 6-speed manual transmission
- Brembo braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red)
- Track model suspension tuning (higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, strut brace)
- Air conditioning
- Note: Automatic transmission not available with R-Spec
GENESIS 3.8: 310 HORSEPOWER AND STANDARD LEATHER INTERIOR – A NEW BENCHMARK FOR PERFORMANCE AND REFINEMENT IN ITS CLASS
Standard equipment includes 2.0T equipment, and adds or substitutes:
- 3.8L DOHC V6 engine with dual continuously variable valve timing delivering an estimated 306-hp (regular), 310-hp (premium), and a top speed of 149 mph
- M6VR2 6-speed manual transmission (Optional: ZF 6HP19 6-speed electronic automatic with lockup torque converter and steering wheel-mounted paddle-shift Shiftronic controls)
- Black leather seats
- Fully automatic temperature control
- Premium door sill plates
- Chrome front fascia accents
In addition to 3.8 equipment, the 3.8 Grand Touring adds or substitutes:
- Unique brown leather seat interior environment
- Power driver seat
- Heated driver and passenger seat
- Heated mirrors with outside turn signal indicators
- Backup warning system
- Sunroof
The factory-tuned 3.8 Track model deletes backup warning system and chrome front fascia accents from the Grand Touring model, and adds or substitutes:
- Aluminum pedals
- Rear spoiler
- Fog lamps
Genesis Coupe will be available in nine exterior colors:
- Karussell White
- Bathurst Black
- Silverstone
- Nordschleife Gray
- Acqua Minerale Blue
- Tsukuba Red
- Mirabeau Blue
- Lime Rock Green
- Interlagos Yellow
Genesis Coupe features four different interior themes:
- Black environment, premium black cloth seats (2.0T, 2.0T Premium, R-Spec)
- Black environment, black leather-bolstered seats with high-friction red cloth insert (2.0T Track)
- Black environment, black leather seats (3.8, 3.8 Track)
- Black environment, saddle brown leather seats (3.8 Grand Touring)
