Is the only place to purchase buckets the dealership? I have a tick sound and from listening it seems to be an intake valve. I'm doing a valve check pretty soon to see. Just wondering where to get the buckets in case I do need to replace them.
to check clearance, take off valve cover
rotate crank by hand and make sure the round side of the lobe of cylinder 1 is facing the bucket.
Use a feeler gauge between lobe and bucket
intake clearance = 0.01~0.03mm
exhaust clearance = 0.02~0.04mm
so for intake if 0.01mm gauge slides through fine and 0.03mm doesn't for intake, then that's within clearance.
same with exhaust, but with 0.02mm and 0.04mm
This is with engine cold
EDIT: I have to go over my documentation. it might be 0.01mm or 0.1mm
I wonder if any of the Chrysler/Mitsubishi/ parts fit?
Looking at the bottom of this eBay listing it has the compatible cars. There's ten pages so it's a common part apparently.
Thats because hyundai buckets don't use spacers to get the clearance. Hyundai makes several buckets for different clearances.
Side note, the valve seals on the 2.0 are the same for both intake and exhaust sides. (I finally got around to rebuilding the head of the engine I'm building, a few weeks ago. :p )
