I have a 2010 gen coupe, 3.8
My washer fluid light has been on for awhile after filling the reservoir up it still won’t go off
I bought a new sensor, part 98520-3e000 and was wondering if anyone has replaced this sensor and what was easiest way to go about replacing
Thank you for reading
Might be able to get it taking the headlight out. That's pretty easy. Be gentle with the clips on the bumper support where the bottom of the headlight slides into. They like to snap off if it's pulled up on. Pull the headlight straight out first a bit. The plastic rivet needs to come out on the bumper and the bumper cover popped up so the headlight is free. Other than that a 10mm nut driver is all you need.
If it's a BK1 then it's easy.
Passenger side front bumper - turn the steering wheel all the way left. remove the 2x push clips that hold the wheel well liner to the bottom of the bumper. just move it out of the way.
You will see the nylon washer tank. the sensor is the circular thing on the bottom of it.
