1 - 10 of 10 Posts
I just got a 2010 Genesis Coupe 2.0t used with 30k miles on it. We have had some really cold/snowy days since I brought it home in the last week. Starting today whenever I turn on the fan (regardless if AC or heat) it makes a clicking noise. It sounds like a wire or something hitting a fan. When I turn it off I can hear the clicking slow down and then stop. Does anyone know what this could be?
GenSport KY
Did you see if something is stuck in your electric fans?
Not yet, I was going to check in the morning. I figured I would ask and see if anyone else has had this problem.
GenSport KY
Where is the heater filter located?
Its called a cabin air filter, there is a DIY on its location and how to change it, But behind the glove box.
GenSport KY
If I have a squeak, I locate the sound and take **** apart until I fix it. Even if it take me a few times of removing different parts. Either way its a win, I will learn more about the Car, or fix a issue. On some rare occasions I break a clip or two and spend a few bucks at the dealer.
Always time well spent.
1 - 10 of 10 Posts
