And the noise appeared after you stopped using the OEM filter?
And the noise appeared after you stopped using the OEM filter?i always went to the dealer to get the filter and washer, but today i bough a gold filter from napa
no... i changed the oil today, the problem started last fridayAnd the noise appeared after you stopped using the OEM filter?
Oh, confused you with the other guy whose issue started today.no... i changed the oil today, the problem started last friday
I thought this same thing but once he hits 3K the pitch never changes or fluctuates at all. One would think a rattle would change a bit through the RPM..It sounds like *something* is loose. Check around the flex pipe, if I recall correctly there is some sort of mesh around there that can rub and cause noise.
I had a similar problem, cause by a bolt missing from my exhaust causing a gasket to flutter back and forth...not enough to hear a loud exhaust leak, but enough to get a good healthy rattle going
And??today i was planning on sending my ecu to jay to get it reflashed, so i choose to remove the exhaust mani heat shield and i noticed i wouldn't get the rattle any more until 4k. so i wanted to push the car alittle and then the rattle went from being at 4k to now 1.5k, i think its the wastegate but we will find out
When in doubt, replace the whole thing?Dealer called today and told me they replaced the tranny and pressure plate and the car should be ready tomorrow. I never had a problem with my tranny so I find it weird they are replacing the tranny too.
