9681 - 9700 of 10044 Posts
In Charge of Snacks
It was weird weather as by the time he turned his Charger around and I stopped we were in the sunshine and he'd turned off his LED lights after he was sitting behind me running my plates etc. I was talking to the local pawn shop owner and mentioned this to him and he figured it was a ticket quota in the works as well and "Just doing His job" taken more seriously than the RCMP would.
In my experience, what you described is not very weird weather for Alberta. Especially Peace River, and the hills west of Calgary. I was driving alongside Barrier Lake one day, stopped by the boat launch for the view, and it was raining across only the middle section of the lake. Sunny at both ends. I mean, that particular lake's only 2 miles long. 3km? Rain "storm" must have only been half a mile across and moving very rapidly. Had the same exact situation outside of Cranbrook in BC, too. Lol, mountains, man... Gotta love 'em.
shorttrack
Just over 11,000 miles on my 2014 3.8 r-spec and the left side inner Tie rod is making a popping sound already , changed both left and right side out for Beck/Arnley's complete inner/outer tie rod assy from ROCKAUTO.com for about $ 34.00 a piece plus shipping,getting alignment next week .OEM tie rod assy appear to have not been greased at all . As I stated before , I like and enjoy my Gen Coupe and how I have built it into a fast as hell car but I would never purchase another Hyundai product ever again .
Heart transplant!
yay......
On another note..... Looking for good "BEEFY" OEM replacement front end links for that black '13. Who's got the plug for a good set that may be an upgrade over OEM lol?
Heart transplant!
yay......
If you are talking about sway bar endlinks - the most heavy duty will be from a Jeep.
They fit aftermarket sway bar hole and coilovers perfect. Stock sway bar you will have to use 1/2 drill bit to make hole a bit larger (as hole is just a hair too small)
https://www.morris4x4center.com/jks-front-adjustable-swaybar-end-link-kit-0-6-0-lift-jks-2943.html?gclid=CjwKCAjw5dnmBRACEiwAmMYGOUeB5ici9SD1RaL99pwbNZ5m4TTP6CUQRY6zA5CISVV8OgSxlUJbzBoC_u4QAvD_BwE
JKS- 2943. Part number
$80
Heart transplant!
yay......
Pretty sure you were the one I was searching for as I remembered reading this a while back lol. Are these same length as OEM? And how much thicker are they? if ya dont mind me asking...
Assuming you are also lowered and have been running these? How have they been?
Ftom my experience, Hyundai products is much better than Chevy.
Things are braking due to your abuse.
shorttrack
Abuse? I would never use your advice Chief.Had I been road racing/tracking my car I would say abuse would be a maybe .As I stated ,the inner tie rod joint was "DRY" , not sure if your reading comprehension caught that description.11,000 mile the inner tie rod should not be dry nor popping .I have research this situation and it seems many Genesis Coupe have early tie rod failures . Do me a favor andbudzi, get more experience .>:D
Well
finally completed this part - small achivment but its done
The material was about 20$ - and total day in amateur turning
No boost leak to outside (OME was leaking a lot)
Better internal seal than OME but still leaking internally
Cant do anything about it using stock membrane with plastic bushing
Still since i have a bit different internal dimension i have more pre-load on the DV spring so it should build boost a bit better :)
https://imgbbb.com/image/XVDGv
2013 Gen COUPE 3.8 GT
On the other hand, we see A lot of bad accidents in wet weather so the goon who is speeding in wet weather is putting everyone in additional danger. The LEO is also aware of this, They get to document all the folks that get smeared all over the asphalt. They risk their lives to stop us from getting hurt and acting stupid and they know the risks of doing it. Its what makes them special.
Heart transplant!
yay......
Got this done today. New motor (well new used with 40k miles lol). So far so good. Runs like a champ 🙂
Retired track car brought back to life as a daily and even smog legal in Cali lol. Wifey approved....
Now the fun begins.... Swapping all of the suspension and roll cage over to my Bk2 rspec 😉. Then topping that all off with the 3point8 performance treatment and custom tune. Prolly take like 6 months but should be fun when its done. Hope summer isnt too brutal in the garage this year 😉
NOOB
Kicked those boring chromed lug nuts to the curb.
My once a year cabin filter and wiper change. First year there was no mouse nest on the cabin filter.
I have to change my filter every 5k miles and it's still dirty despite not smoking or driving with the windows down or sunroof open. When I first changed the filter at 10k miles which is the factory recommended interval the filter was absolutely filthy so 5k it is from now on.
Today I checked my coolant with the multimeter and a ph test strip both of which showed as fine, and another strip along with a brake fluid tester showed that the bf was good as well. Oil was surprisingly low near a quart at 4k miles since last oci despite no visible oil leak so I'll have to keep my eye on that sitch as it's never happened before. Fixing to hit 100k miles and will get another UOA.
In Charge of Snacks
Finally tackled my giubo replacement. I did it because my carbon driveshaft wasn't going to arrive in time to go camping with the nephews. Then I found out this morning that trip is cancelled. My sister knew about it for a week and failed to mention it. LOL, wow. anyway, here's a new giubo in place, and my car's rear hoisted sky high. Thought I'd share.
BTW, giubo surgury,... Highly recommend a 20+ inch breaker bar and a ratcheting wrench. I gave myself plenty of room and even with these nice tools, it was still a b1tch.
Also. I have another new giubo to replace the front unit. I'll have two freshies for anybody who wants them once I get the new driveshaft installed and tested. Let me know if you need one or two.
Irresponsible Rookie
Did you use the OEM guibos that are like $200? Or do you know of any other options?
I think I remember that BMW had an option that might work.
Installed these beasts yesterday. Cured my issues. No sounds, no thumps. Better feel. Happy man. Will see how they hold up.....
#notowhitelinelinks .com/.org
-SC
In Charge of Snacks
I used the ones made in Germany. They are the same dimensions exactly, so they may be BMW OEM, but they did not bear the Rondell or BMW name anywhere. And they specifically say made in Germany, as opposed to stock which specifically says made in Korea. I've had them for a bit as they were supposed to be replacements for a bud who totalled his gen. Also, they do seem to be of a higher durometer rubber. Probably means something to someone. LOL, carbon fiber is en route so I'm not too concerned. For any who care, my stock piece was very deeply cracked as well. I've had the car 9 years and it has 95k on the odometer.
I think I paid around $45 each for them...?
#notowhitelinelinks .com/.org-SC
You know, this is a good tack... Use a beast threaded rod and female threaded rose joints or ball joints instead of a male threaded spherical rod-end. I noticed on McMaster the other day they sell 1 meter long rods of M12 with 1.75 thread in 12.9 steel for about $40/each. Those should outlive the car...
With this method you could even use bulletproof sealed rose joints from like, QA1 and the like.
I got mine at Amazon for around $70 each though they are out of stock now. Here's the German part number. SGF GAH04-005 - OEM German Made Flex Coupler - Bolt Circle 105mm/Bolt Hole 12mm/Bolt Hole Length 35mm
[ame]https://www.amazon.com/gp/product/B00MYF4820/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1[/ame]
