10321 - 10327 of 10327 Posts
Changed thermostat. Hyundai out Hyundai in. Not the original. Third one IIRC. 1st one got lazy and would not fully close. Not a problem unless driving in the winter. This one I took out was opening at a higher temp that normal (185F) and sometimes stuck closed as the temp would shoot over 200F then suddenly drop to 183F or so. But lately with the heat in the 80Fs its been going to 189F and staying there.
New one opens at 183F and runs around 185F once all warmed up. It's rated at 180F/82C.
Those tail lights look incredible! Did you end up reusing your OEM taillight gaskets or the new ones that came with the Spec-Ds? Also, did you silicone seal them?
The old gaskets looked to be in great shape,, but are still attached to the original tail lamps. I cleaned up the area before installing the spec D's with the gaskets provided, from the inside of the trunk with a light They look to be sealed up good. In seven years my coupe has never seen water. I am aware of the water in the trunk issue with the coupe, the spec D's seem to mount flush with the car body with no gap but I might add a strip of clear tape along the top edge just in case I ever actually get caught out in a real rain storm. I'm more concerned with the spec D's throwing the car into limp mode, so far so good. I like them the way they are, don't really want to have to do the "Audi mod".
Went to the Dyno again to see my before and after SFR on my Dyno. Also bought upgraded size tires 255/35/19 R
235/35/19 F
Firestone Firehawk Indy 500's.
They are coming in another thread. I'm doing before and after walnut blast results.
Reactions: Red Raspberry
