1 - 5 of 5 Posts
So, I am a new member and and a new gen coupe owner. The car is a 2013 and I am preparing to install a heated seat kit and noticed a switch I have no idea the use for. It’s right under the traction control and light knob. Is it stock? I looked around and couldn’t find anything about it.
75982
Thats not standard. Previous owner installed it.
Maybe for fog lights?
OEM fog light switch is suppose to be on the left steering wheel stock.
So, I am a new member and and a new gen coupe owner. The car is a 2013 and I am preparing to install a heated seat kit and noticed a switch I have no idea the use for. It’s right under the traction control and light knob. Is it stock? I looked around and couldn’t find anything about it. View attachment 75982
Gotcha, it’s not fog lights. I am actually looking to order an oem kit for that. Unless they pulled them out before selling? I installed a dash cam and didn’t see anything leading from the fuse so I figured it “might” be stock. My next day off I may pull the panel back and see were it leads to. Thanks!
Hyundai uses that same switch for fog lights on 2008 Accents. OE ours is just a blank behind that. I bought a fog light kit off Amazon and it came with a direct replacment for that switch. I have it if you need it as I didn't use it. Might take a while to find.
So what you've got there is TCS & SCS toggle switch, Dashboard Dimmer Switch and an Illuminated AfterMarket Rocker Switch (probably 3-prong) for installed lighting or accessories. I've got the same switch installed myself but I put mine to the right of the dimmer switch and have it powering my Auxillary Fog Lights. The previous owner did quite a sloppy job with that one lol I like the blue tho
1 - 5 of 5 Posts
