What size drag radial to put on stock 18" rims?
983 Views 3 Replies 2 Participants Last post by  rspec20
So I have a 2010 R-Spec, and i'm going to buy a set of stock 18" rims. I want to know what size drag radial to put on the back and what size tire to put up on the front?
245/40/18 Mickey Thompson ET Street Radial.
Or try to drop down to a 17" wheel
Thanks for the reply. I would love to go to a 17" rim, but the Brembros won't clear. Do you happen to know what size tire to run on the front, I figure I'll just run stock size whatever that is for the 18's.
i'd run the stock tire size up front...
You might consider a set of used Evo 8 17's that will fit...Can find them for $400 for the set. They're lighter, tires are cheaper, and they'll perform better on the strip
