Hello, just wondering if anyone has wheel spacers and if so do I need extended studs? I’m getting 20mm spacers for the front and 25mm for the back. Thanks.
At that thickness I believe they come with their own studs.
I have 12mm and needed studs.
For your spacers, your OE studs should be fine.
Bolt on spacers will be fine, if you are getting spacers that fit over your existing studs you will need extended studs.
