1 - 12 of 12 Posts
STATE OF THE ART Camshafts for your Hyundai Genesis 2.0T​
GSC S1 Camshafts Set​
*The GSC Power-Division S1 cams for the Hyundai Genesis Coupe 4B11T are designed for those with the stock turbo up to the 550hp range*​
Price too low to list, click here!
- These cams will not sacrifice any bottom end loss over stock cams; nothing but gains and will promote faster spooling of the upgraded turbos. Gains of 20-50whp (depending on Turbo) have been seen by simply bolting the S1 cams in.
Designed for a rev range of 3000-7500rpms, these cams work well on the stock valve springs.
GSC Hyundai Genesis Cams Features:
- Designed for a rev range of 3000-7500rpms
- Intake 264 / 220 @ .040" / Peak Lift 10.2mm
- Exhaust 264 / 216 @ .040" / Peak Lift 10.0mm
*The GSC Power-Division S2 cams for the Hyundai Genesis Coupe 4B11T are designed for those with 600HP+ in mind*​
- Gains of 20-60whp have been seen by simply bolting on the GSC S2 cams (depending on Turbo).
- Designed for a rev range of 3500-8000rpms
- Intake 272 / 226 @ .040" / Peak Lift 10.4mm
- Exhaust 270 / 222 @ .040" / Peak Lift 10.2mm
BOTH PARTS FIT Hyundai Genesis Coupe 2.0T
So are these cams ACTUALLY for the Genesis Coupe THETA motor? or are they ACTUALLY for the 4B11T?
Because im pretty sure, even though both motors are cast from the same block of aluminum. they share pretty much nothing else in common.
Discussion Starter #7
Spoke to our production manager, these are for the Genesis Coupe THETA motor! Thanks for reaching out to us LeesEvoGenX! :)
- Dan
- Dan
just thought id note it. the gen needs more cam options, but right now think they are stuck modifying cams that are made for the 4b11t
1 - 12 of 12 Posts
