I just replaced my original headlight bulbs and I just noticed that the drivers side low beam has a dark spot the passenger side doesn’t.
Atmosphere Automotive lighting Hood Automotive tire Road surface
Looks as if your driver side is way up while the passenger side is down. I like to face a wall at night where i can see the beam pattern. The driver side should be slightly lower than passenger so as not to be blinding to oncoming traffic, just adjust your headlight down some.
How I set up to adjust headlights.
Pull right up to a wall and mark where the center of the headlight beam is.
Back up (on level ground) 25 feet. Then adjust the center to the spot.
If it seems you may be cranking and nothing is happening or you can't seem to get it back to what you want.
Turn the adjuster screw (8mm) completely to the limit in one direction (makes no diff which). Be careful to stop and not over extend.
Then turn all the way back to the opposite limit counting the number of turns. Then turn it back half the turns.
This should get it close to where it should be.
