1 - 8 of 8 Posts
I have to dynojet wideband2 hooked up to the cmd, when I look at the guages on the software (on the computer) they all work except the AFR gauge. Any suggestions?
3.5L TT but wrong body
Did you put the blank can bus plug in?
Power light on? Change a/f gauge in mcc to use lamda value under properties?
Let me know if you want me to take a look at this, as i am local.
make sure you have enabled auto-tune in the configuration in MCC
A few things to check...
  • Make sure you are using software version 1.1.7.1 and firmware 1.5.1 - if not, download it from the website (Dynojet Research Inc. Combustion Management Device(CMD))
  • Make sure the CAN terminator plug is installed in one of the open CAN terminals
  • The gauge may not be "linked" to the air/fuel channel in the setup - right click the gauge and click properties. Make sure the channel is set to WB2_AFR. It will only display Lambda, not air/fuel.
  • Look in the Table View and see if the channel displays data in that view.
Found it. Thanks guys it ended up I needed to change the lamda number values mid/max. Under 2.0 for it to be read, so retarted. Bill, But if I need help tuning cause the people I know are not familar with tuning a turbo can you help???
Just sent you a PM, i will be at All Jap Cars all day tomorrow from 9am-2pm(they close early on saturday).
Anyone else who wants to come is welcome as well
4897 N. University Dr. #B, Lauderhill, FL 33351
1 - 8 of 8 Posts
