1 - 11 of 11 Posts
Hey i have a genesis coupe 3.8, I wanted to know any suggestions on good tires? I am looking for slightly wider tires
Try to go for lighter tires - better acceleration. They affect acceleration more then lighter wheels.
Continental extremecontact sport
Is the lightest tire out there.
I run 245/35r19 F and 265/35r19 R
Thanks I appreciate you!
Would it affect the traction though?
i use 245/30/20 on all around on mine so i would recommend getting 245 in the back and wheel size of 19. the 20's are a bit to much and makes the ride a bit much i would reccomend what @andbudzi said
Continental are also very good with traction, right on par with Michelin super sport. Much better then OEM, especially in wet
Reactions: jayjay2
I have stock sizes on the stock 19's.
I'm currently using spacers 25/20mm
I have 255/35/19
And 235/35/19 tires In the garage ready to go on.
Should i remove the spacers now? They look great with stock width.
I don't want my tires sticking out past the fender wells. I don't see any info about leaving them on or taking off the spacers with wider tires.
I have 255/35/19
Keep the spacers on unless you want the rear tires to be inside the rear fender. They should be flush with the spacers
15' 380GT BK2 M/T Caspian Black ;P
Say fooq it and go 19x9.5 +22 on 245/35/19 and 19x10.5 +22 on 275/35/19 and get flush like a portajohn.
but the firestone fire hawk Indy 500 is a good tire. Has better wet performance than my old all seasons... Although I was running nankang ns-25s lol
1 - 11 of 11 Posts
