1 - 20 of 27 Posts
Just wanted to share, got the front and rear done. Yes they are orange, custom color.
14" front rotors with 6-Piston W6A (Enjuku Kit, same as before with new color caliper).
The Front Wilwood kit will be a 14" front rotor with the 6-piston Forged Superlite.
13" rear rotors with 4 piston Forged Superlite calipers, works with OEM parking brake.
They should have it ready within the next two months.
That was taken with my phone, I will get nicer ones this weekend, had a hell of a week with two oral surgeries.
2012 3.8 Track ZF-6-SPD
I will try to get some estimated Pricing, but going off of the 370Z 14" brake package, the front will be retail $1926.39
For those looking for an upgrade, they are also lighter that OEM and OEM Brembo's. 14" rotor weighs under 20 pounds with the hat. Caliper weighs about 5.5 pounds.
'11 3.8 Silverstone
These look pretty nice, Wilwood has been around for a while and make great products. How do you like them compared to the base brakes?
Discussion Starter · #12 ·
Over the Base brakes, it is a huge improvement. Pedal feel is same, does not require more travel, but car stops much more efficient. Parking brake works like OEM.
I will get closer pics this weekend. Off to a rugby game
can we put 14" rotors on the front if you already have the stock brembo's? they are 13.4" stock…. dunno if its a stu[id question.
Discussion Starter · #14 ·
Usually that is not possible as the caliper would need to come up over 0.5" to support the height of the larger rotor. This means a custom bracket would be needed.
Also the inside radius of the OEM Brembo may not support the high of a diameter. This means the top of the rotor could hit the inside of the caliper.
Sorry for the delay, if you were at the last 805 meet you got to see them in person. Here are some closer pictures.
Captain Awesomesauce
Those are so sexy. I'm trying to save up for OEM Brembos. There's no way in hell I'll ever be able to afford an aftermarket BBK T_T
Discussion Starter · #18 ·
How much are OEM Brembo's going for?
$1000ish
I'm talking used off a wreck on eBay or a hookup if you know someone. I know a guy up here that got his out of the junkyard for $750, calipers, pads, rotors and dustshields.
GCMafia
$1000ish
Yeah I got mine with slotted rotors and almost new lads for 800 on Craigslist
1 - 20 of 27 Posts
