1 - 8 of 8 Posts
Hey guys. I just put my winter tires on my gen. and i have notices that when i accelterate kinda hard my traction control light flashes and i loose power(as if i was spinning tired with tc was on). I thought maybe cuse i actually was spinning tires so i tried flooring it in 5th gear doing about 100km/h and the same thing happened. Does anyone know whats wrong?
It sounds like you put a different size tire on than the OEM and the traction control thinks they are spinning. I'm guessing you went with narrower tires but kept the same sidewall ratio or you went with a square set-up?
Advenio Pariter
I use a square winter setup and my ECS goes wonky like that. When I replace my winter tires I will go to a staggered setup. Turn off the ECS and drive commando...
No problems running square winters , mine are 17 in. ( OEM 18in. for summer ) 225/50 front and 225/55 rear . Taller rear side wall gives the proper ratio. I drive with TC on most of the time in the winter .
Reactions: TsukubaRed_PA
What are your tire sizes (front tires and rear tires)?
1 - 8 of 8 Posts
