1 - 3 of 3 Posts
Hi guys,
I was hoping someone could tell me what the wires in the passenger C-Pillar are? Obviously some is going to the rear defroster and I assume the rest are going to the amp that's lower behind the panel?
I'm just trying to find something I can tap into and install a dashcam in the back window. Would any of those be suitable?
Haven't had much luck finding a good diagram or explanation, figured I'd ask around here before I pulled more panels off to see where they go.
Thanks!
Edit: Here's some pictures of what I'm talking about. There should be an always hot and a switched power in that bundle right? Not sure what the third would be, the actual speaker signal maybe?
https://imgur.com/dzX4KdM
https://imgur.com/toOKtKQ
https://imgur.com/MipcxZY
DON't mess with any of those wires... your likely going to trigger the side curtain airbag
use the wires in the lower door sill panel.
1 - 3 of 3 Posts
