1 - 8 of 8 Posts
3.5L TT but wrong body
Try pming rspecwhite. He just wired his a little bit ago.
..Cody at lovefabb. They have made a plug and play harness.
Good luck with that. He's been ignoring at least a couple of members on this site. He still owes me a hotside IC pipe from over 3 months ago.
If he does respond, please ask him to ship my frakin piping out :)
old guy
Does anyone have the diagram for wiring up a universal FIC to our harness?
A how to would be even better, thanks!
You can get the ecu pinout by doing a search on this site.. There is one error in it though. Pins 31 , and 51 are labled incorrectly. The one that says it is map1 is actually iat1. The one labled iat is the map1 line that you want to intercept. You have to pry off the release lever, and the wiring loom guide to get access to the back side of the ecu plug. Just be very careful that you have located the correct wire before cutting. I used the non insulated butt spices covered with heat shrink. It takes up less room than the insulated splices, and is neater. Do NOT under use the scotchlok type as they will give you problems down the road. The whole job takes around 2 hrs going slow and careful. Good luck, and if I can help shoot me a pm. Jack
Back to Stock!!
some of the throttle wires are crossed too
I found out when wiring the Porsche throttle. I'll have to check which is which, but just a headsup
1 - 8 of 8 Posts
