It’s been quite a few years since I bought my GC brand new and now I’m finally going to be doing a proper engine build now that I’ve got pretty much no warranty left.
This build page will cover the parts, process, progress and suppliers to my build as I’ll be doing reviews on the products themselves as well as multiple dev diaries covering the build from start to finish, so expect a lot of videos.
First off, the goals and expectations of this build. As some may know from my determination to build the most power OE tuned GC, where I reached 206whp and 236wtq, I’m a rather conservative builder and prefer longevity to record breaking numbers. The main point of this build is to take an in depth look at the engine and transmission of the Genesis Coupe and fix all of its short comings while keeping the stock turbo, essentially a super stock performer. While taking into the consideration of the limits of the stock turbo, peak power goal is a modest 250whp and 300wtq, if we hit more, excellent. This is not record breaking by any means however it’s where the power is and how it’s delivered that will speak the most of this build, not to mention, the years of future reliability and how it performs for roughly the next year will shape it’s successor, Project Red Baron’s design plan.
Second, who I’m working with on this.
One of the best guys I’ve ever had the pleasure of working with on an auto project, Mr.Saikou from Saikou Michi Co., who not only provided the oil catch system for my car but also made it a production unit for the whole community.
Uniq Performance has been the number one supplier for me ever since they came into the GC community. Not only does Rob offer excellent customer service, but the convenience of dealing with a fellow Canadian has made things cheaper for me in the long run, his massive amount of product selection and the fact that he actually carries stock rather than having everything drop shipped from warehouses typically means I get things stupid fast.
Piranha Racewerks has joined the team providing technical expertise, unique one of a kind products and support during and after the build.
GrimmSpeed has done all the porting on the turbo, exhaust manifold and intake manifold to aid air balance, turbo spool and hopefully give some more up top.
Fred Bean Hyundai (FBHyundai) will be providing all the OE parts that need to be replaced such as gaskets and fittings, excellent pricing, great support and no issues shipping parts to Canada.
ATQ auto provided all the shifter related equipment, fantastic accessories to suit our rather temperamental manual transmissions.
Alphaspeed is providing the ECU tuning to the Haltech system as well as technical support.
With more partners coming onboard as the project starts to take shape, stay tuned to this section as not only will I be reviewing the products I buy from them, but I’ll be reviewing them as well.
So onto the parts;
Engine;
Internals;
- ACL race series rod bearings
- ACL race series main bearings
- ARP cam tower studs
- ARP head stud kit
- ARP main stud kit
- ARP flywheel bolts
- Custom balanced OE crank shaft
- Hyundai head gasket
- K1 forged connecting rods
- Wiseco 86mm forged pistons
Exhaust;
- 2013 cat-back
- ISIS downpipe
- Ultimate Racing high-flow metal core secondary catalyst
- Uniq Performance O2 housing
Cooling;
- BR heat shields
- CFS radiator w/Fumoto QuikDrain valve
- DEI heat tape
- Hyundai water/oil cooler
- Mishimoto heater core hoses
- SPAL 11" radiator fans
- Uniq Performance LP rad twin-fan shroud
- Venair radiator hoses w/aluminium upper pipe
Intake, turbo and intercooler;
- AEM drop in panel filter w/ box mods
- ATQ throttle adapter
- Custom Air/Water intercooler w/Bosch Cobra water pump
- Devils Own meth injection w/ D04 nozzle
- Forge Motorsport wastegate
- GrimmSpeed flow balanced intake manifold (custom)
- GrimmSpeed PnP compressor housing (custom)
- GrimmSpeed phenolic spacer
- Polished throttle body and plate
- SECo FMHE w/ SPAL fans
- SECo TD04HL-9-GTX19T-TS
Tuning and fuel;
- Alphaspeed custom ECU tune (Haltech)
- Haltech Pro Plug-in ECU
- DLC custom ECU tune (OE ECU)
- Piranha Racewerks Fuel return kit
- Piranha Racewerks 4-Bar MAP sensor
- Saikou Michi vacuum tank
- Siemens 750cc injectors
- Synapse DV BOV
- Warlbro 400lph fuel pump
Misc. and dress-up;
- ATQ strut tower caps – panda style
- Fumoto Qwik drain valve - oil drain
- Gates PowerGrip hose clamps
- Saikou Michi Catch Can
- SickSpeed oil cap
- Valve cover – ceramic titanium blue
ECU and diagnostics;
- V-Gate OBDII module
- SECo 10-Bar oil pressure sensor
- PX Flash tuner
- Zeitronix ZT-2 w/ LCD display, 3.5 Bar MAP sensor, A/W Temp Sensor, IAT Sensor, Fuel Pressure Sensor
Transmission;
- ATQ short shifter
- ATQ rear shifter bushing
- ATQ shifter bushings
- Techna-Fit SS Clutch Line - blue
- Valeo HD clutch kit
- Valeo 2013 Dual-mass flywheel
- Valeo HD clutch slave cylinder
- 2013 shift knob
- 30A dura transmission mount fill
Brakes;
- Brembo calipers - burple
- EBC RedStuff pads
- EBC USR rotors
- Techna-Fit SS Brake lines - blue
Suspension;
- 2013 R-Spec struts
- 2013 front end links
- ATQ rigid collar kit
- Body colour GT Strut bar
- Eibach Sportline springs
- MOOG rear end links
Exterior;
- ATQ skid plate
- Custom OE vented Fog Bezel - intake side
- KDM Power folding mirrors; heated, LED turn signals
- Tinted rear windows
- Wing badges
Lighting;
- 2013 tail lamps
- Diode Dynamics Interior Stage 2 LED
- Diode Dynamics 6000k bulbs
- GE Nighthawk Highbeams
- KDM Headlamps
- Lamptron Vandal Ring Switches
- Putco 3000k Halogen Foglamps
- SuperLumination LED; AW Switchbacks, backup lamps, rear turn signals
Wheels and tires;
- Volk Racing Formula lugs
- Nismo stubby valves
- Summer:
ForgeStar F14 – Gloss Black
Front: 18x8.5 +26 Rear: 18x9 +20
Nitto Invo
Front: 245/45r18 Rear: 255/45r18
- Winter:
Stock 18x8 four corners
Michelin X-ice XI2
Front: 225/45r18 Rear: 245/45r18
Interior;
- 2014 Premium black leather heated seats w/power position
- Auto A/C conversion
- Custom Blue/White needle gauge cluster
- F-series upfitter switches
- Interior trim pieces – 2011 style
- OE Premium trunk deck
- OE "Genesis" brushed aluminum door sills
Audio/Video;
- Backup camera
- Custom center console RCA wiring
- DEI sound deadening
- Hertz HCP 5D 5-channel amp
- Hertz 165.5 door speakers
- Hertz 165 rear speakers
- Hertz ES F20.5 subwoofer
- HushMat sound deadening
- JYCustoms Type-A bezel
- Newsmy 7" HD Android head unit
- Scosche Wiring
- UNAVI X2 8”
Now while some of these parts are already installed, some are awaiting installation and some still need to be acquired. Information on the already installed parts is available on my YouTube or in my alternate build thread.
In the coming months I’ll be doing constant videos of parts as I get them, reviewing the parts themselves as well as the provider. We’ll be taking an in depth look at the engine with a running commentary from yours truly as I take apart the engine and will be providing constant updates to the rebuilds progress as well as covering some of the more advanced how-to information as I take on my most invasive project yet with the Genesis Coupe.
If you guys love how I’ve taken on other projects for the GC, you’ll love this so sub and stay tuned.
So onto the parts;
Engine;
Internals;
- ARP head stud kit
- ARP main stud kit
Exhaust;
- 2013 cat-back
- ISIS downpipe
Cooling;
- BR heat shields
- DEI heat tape
Tuning and fuel;
- Synapse DV BOV
Misc. and dress-up;
- SickSpeed oil cap
- PX Flash tuner
Transmission;
- ATQ short shifter
- 2013 shift knob
Brakes;
- EBC RedStuff pads
- EBC USR rotors
Suspension;
Exterior;
- ATQ skid plate
- Wing badges
Lighting;
- 2013 tail lamps
- KDM Headlamps
Wheels and tires;
- Summer:
Nitto Invo
- Winter:
Michelin X-ice XI2
Interior;
Audio/Video;
- Backup camera
- Scosche Wiring
- UNAVI X2 8”
