1 - 1 of 1 Posts
I have an Aimpoint Comp M4 2 MOA optic for sale or trade its in like new condition, it only been on a rifle fired a few times. I am asking 650 shipped or would trade for an Aimpoint T-1 2 MOA. Includes both the vertical and cantilever mount, as well as a mount to intall on an upper with a carrying handle. Original instructions and pamphlets included as well as all hex keys. New these go for $829 without the cantilever mount.
Everything included:
Serial #:
On the rifle:
Features: (From Aimpoint)
-Compatible with every generation of Night Vision Device (NVD)
-Super ACET technology allows up to 80,000 hours over 8 years
of daytime operation on one AA battery
-1x (non-magnifying) parallax-free optic.
-Internal voltage regulator allows the CompM4 to be used with any AA sized battery.
-7 night vision compatible settings and 9 daylight settings Improved rotary switch will not suffer damage under normal use.
-QRP2 mount has twice the clamping force of the original QRP, and -the mounting knob is wider and shorter to improve operation, and lessen the chance of becoming snagged on other gear
-Mount base is “keyed” into the body of the sight to absorb recoil
-Mount base screws directly into the sight – no separate sight ring is required
-500,000 hours of use on NVD setting
-2 MOA dot for close combat and long-distance engagement
-Matches perfectly with Aimpoint 3X Magnifier
-Unequalled light transmission
-Front lens opening is threaded for addition of the Killflash anti-reflective device
-Submersible to 150 feet (45 meters)
-Vertical spacer included
-Standardized as the U.S. Army’s new CCO.
-Improved adjustment caps are easier to remove, and are protected against impact
1 - 1 of 1 Posts
