ARP Head and Main Stud Kit-For 2.0 Gen Coupe! - Hyundai Genesis Forum
post #1 of 19 Old 02-06-2014 Thread Starter
CPERFORMANCE's Avatar
Please send me a PM or give me a call for your order. Like Ciocca Performance on Facebook for special offers and coupon codes that you can use on our website.
Part #: 228-4301 (Head Stud Kit)
It is for good reason that virtually every top professional engine builder relies on ARP Pro Series head studs for their all-out competition powerplants. Simply stated, there’s not a better stud setup on the market today.
For openers, ARP uses a premium grade 8740 alloy that is rated far superior to “aircraft” quality. Each stud is placed vertically in special racks and precisely heat-treated to 200,000 psi. This procedure ensures complete heat penetration and the results are far superior to those lesser quality studs from other manufacturers who just dump pieces in a basket and hope for the best.
Following heat-treat, each stud is centerless ground to make it as close to perfectly concentric as possible. This procedure involves about ten very slight cuts and results in an exceptionally straight part. It’s important to note that lesser quality studs are not even centerless ground – the material is thread rolled in bar stock form (mostly before heat-treat, when the material is easier to machine). Because ARP studs are manufactured to such exacting tolerances, you will note that gaskets and cylinder heads literally glide into position and are perfectly aligned – something that won’t happen with inferior quality head studs.
ARP studs are thread rolled after heat-treat, which gives them about 1000% (that’s ten times) better fatigue strength than those studs that are threaded prior to heat-treat (a very common industry practice). It costs a lot more to do it this way, because it’s tough on tooling, but the results are well worth the extra effort.
You will also note that ARP offers specially undercut studs for several engines. This procedure (done only to the shorter studs) more equalizes the “stretch” of both studs, which makes for a more consistent clamping force – and one that compensates for head gasket compression when the cylinder heads are installed. This helps prevent blown head gaskets, and assures optimum engine sealing!
Premium quality heat-treated 8740 chrome moly steel head stud kits are available for most every domestic and import applications.
You won’t find a better quality stud on the market from any other source. Look for ARP stamped on each stud as your assurance of quality.
Clearly, ARP Head Stud/Bolt Kits are the best on the market today, and the favorite of leading professional engine builders in all forms of racing.
Part #: 228-5401 (Main Stud Kit)
There are many important reasons to use ARP main stud kits, including the elimination of main cap walk and fretting, as well as protecting the threads in your engine block. All kits come complete with hardened parallel-ground washers and high quality nuts. Some applications have provisions for mounting windage trays and have specially designed standoff studs with serrated lock nuts to position the windage tray and lock it securely in place. The studs are manufactured from 8740 chrome moly steel, heat-treated in-house to 200,000 psi tensile strength, and precision J-form threads rolled after heat-treat to create a fastener that has threads 1000% stronger than others.
CPERFORMANCE is offline
post #2 of 19 Old 02-07-2014 Thread Starter
good deals.....
post #3 of 19 Old 02-10-2014 Thread Starter
good deals.....
post #4 of 19 Old 02-12-2014 Thread Starter
good deals.....
post #5 of 19 Old 02-14-2014 Thread Starter
good deals......
post #6 of 19 Old 02-18-2014 Thread Starter
good deals.....
post #7 of 19 Old 02-20-2014 Thread Starter
good deals.....
post #8 of 19 Old 02-25-2014 Thread Starter
good deals.....
post #9 of 19 Old 02-27-2014 Thread Starter
good deals.....
post #10 of 19 Old 03-03-2014 Thread Starter
good deals.....
post #11 of 19 Old 03-05-2014 Thread Starter
good deals......
post #12 of 19 Old 03-07-2014 Thread Starter
good deals.....
post #13 of 19 Old 03-11-2014 Thread Starter
good deals.....
post #14 of 19 Old 03-13-2014 Thread Starter
good deals.....
post #15 of 19 Old 03-17-2014 Thread Starter
good deals......
post #16 of 19 Old 03-19-2014 Thread Starter
good deals.....
post #17 of 19 Old 03-21-2014 Thread Starter
good deals.....
post #18 of 19 Old 03-25-2014 Thread Starter
good deals.....
post #19 of 19 Old 03-27-2014
Norman,OK
burks95's Avatar
Can you please pm the best you can do for both main and head studs shipped to 73072?
[CENTER]2010 Black R-Spec 2.0T
burks95 is offline
ARP Main Studs for Gens manufactured in early/mid 2010's dewkiie 2.0T Discussion 2008-2012 2 11-07-2015 01:13 PM
WTB: ARP Head Studs & OEM Gasket RCP Want to Buy 0 11-19-2013 07:00 PM
ARP head studs sqsound Québec 2 08-12-2013 05:09 PM
ARP bolt and stud kit review Snoopy0812 Product reviews 1 08-01-2013 07:17 PM
Open Letter on N7 build; Critical Notes regarding 2.0T main stud selection and use Quartermaster 2.0T Discussion 2008-2012 146 08-15-2012 12:13 PM
