Official Genesis Coupe Wheel Fitment Thread - Page 254 - Hyundai Genesis Forum
 159Likes
post #5061 of 6302 Old 01-23-2015
Genesis OG
J Long's Avatar
Quoted: 190 Post(s)
J Long is offline
post #5062 of 6302 Old 01-23-2015
"Bentley" Owner
Copp3rhead's Avatar
Quoted: 88 Post(s)
Originally Posted by J Long View Post
I've been utilizing this thread and the OP's table, however, something doesn't seem quite right since my 20x9 +35 wheel is sitting flush up front with no spacers?
2013 3.8 Grand Touring [+ R-Spec Goodies]
Mods
- BTR Canned Tune
- Brembo Brake Swap
- R1 Slotted Rotors
- Stop Tech Performance Pads
- Enthuspec SS Lines
- LSD
- ARK GRiP V2 Exhaust (Polished Tips)
- ARK H-Pipe
- ISC Coilovers (Track Series)
- R2C SRI (Black Nickel)
- DD HIDs (6000K)
- DD Stage 3 Reverse LEDs
- DD Stage 3 Fogs
- DD Stage 3 License Plate LEDs
- Tints (20%)
- Saikou Michi Oil Catch Can
- BBM Lip Spoiler
- Sequence CF Diffuser
- SSR 3 Piece Evolution GP-0
Copp3rhead is offline
post #5063 of 6302 Old 01-23-2015
Genesis OG
J Long's Avatar
Quoted: 190 Post(s)
Something is off cuz no way an offset that high is sitting flush. Judging by your pics, sure you dont have 20x10 all around?
2013 3.8 Track M/T
BC Racing Coilovers
R2C Intake
ARK Downpipes
ARK Test Pipes
Custom CNT V3 w/ X pipe
SFR Custom Tuned
19x11 +18 265/30
Xenon Depot 6500K D1S HIDs
6000K Switchbacks
6000K LED Fogs
Full Time DRL's
RGB Halos
Custom Interior LED Kit
6W Reverse LEDs
20% Tint
J Long is offline
post #5064 of 6302 Old 01-23-2015
"Bentley" Owner
Copp3rhead's Avatar
Quoted: 88 Post(s)
Yea they don't have the non concave Vicenza's in anything higher than a 20x9.
Mods
- BTR Canned Tune
- Brembo Brake Swap
- R1 Slotted Rotors
- LSD
- ARK H-Pipe
- DD HIDs (6000K)
- DD Stage 3 Fogs
- Tints (20%)
- BBM Lip Spoiler
post #5065 of 6302 Old 01-23-2015
POV Futografee
Tilley's Avatar
Quoted: 36 Post(s)
Yea, no way that's sitting flush... unless your definition of "flush" is different than others, or they sent you the wrong offset lol
Tilley is offline
post #5066 of 6302 Old 01-23-2015
"Bentley" Owner
Copp3rhead's Avatar
Quoted: 88 Post(s)
I'm thinking I may have the wrong offset. I'll go 15/20 for the spacers and that SHOULD clear my coils. The ISC coils are identical to HSDs which have clearance issues. Can anyone confirm a 15/20 spacer setup will allow clearance?
Mods
- BTR Canned Tune
- Brembo Brake Swap
- R1 Slotted Rotors
- LSD
- ARK H-Pipe
- DD HIDs (6000K)
- DD Stage 3 Fogs
- Tints (20%)
- BBM Lip Spoiler
post #5067 of 6302 Old 01-23-2015
POV Futografee
Tilley's Avatar
Quoted: 36 Post(s)
If you're talking coil/strut clearance with a flush fitment, a 15mm spacer is ideal with a 9" wheel with a +35 offset
Tilley is offline
post #5068 of 6302 Old 01-23-2015
"Bentley" Owner
Copp3rhead's Avatar
Quoted: 88 Post(s)
Yes that's exactly what I'm referring to, however, the ISC/HSD coils run thicker than OEM suspension, isn't this something I should worry about?
Mods
- BTR Canned Tune
- Brembo Brake Swap
- R1 Slotted Rotors
- LSD
- ARK H-Pipe
- DD HIDs (6000K)
- DD Stage 3 Fogs
- Tints (20%)
- BBM Lip Spoiler
post #5069 of 6302 Old 01-23-2015
POV Futografee
Tilley's Avatar
Quoted: 36 Post(s)
Those coils are only larger by a small amount... you'll be way good with a 15mm spacer
Tilley is offline
post #5070 of 6302 Old 01-23-2015
"Bentley" Owner
Copp3rhead's Avatar
Quoted: 88 Post(s)
Awesome news then, thanks Tilley.
Mods
- BTR Canned Tune
- Brembo Brake Swap
- R1 Slotted Rotors
- LSD
- ARK H-Pipe
- DD HIDs (6000K)
- DD Stage 3 Fogs
- Tints (20%)
- BBM Lip Spoiler
post #5071 of 6302 Old 01-24-2015
je13's Avatar
Quoted: 56 Post(s)
Is this pretty much stock fitment?
Braelin BR03 19" staggered rims
5x114.3 bolt pattern
Front 8.5x19
Rear 10x19
Toyo Proxes tires
Front 225/40/19
Rear 245/40/19
Came off of a Infiniti G35 with Brembo brakes.
Here's the ad http://www.kijiji.ca/v-tires-rims/ca...ationFlag=true
je13 is offline
post #5072 of 6302 Old 01-25-2015
Break Necks - Kill Egos
johal's Avatar
Quoted: 111 Post(s)
The wheels are wider than stock.
Daily - '14 Taco TRD
Project - '12 2.0t
|TurboXS GTX3076R|WORK Wheels|Track King Racing|Haltech|
Instagram: rjoha1
*not sponsored*
johal is offline
post #5073 of 6302 Old 01-25-2015
je13's Avatar
Quoted: 56 Post(s)
Picked up these Braelin BR03s today:
Front 8.5x19
Rear 10x19
BUT had a bit of an awe crap moment. The centre bore on these is 66.4, and they genesis centre bore is 67.1. The guy I bought them off siad they were on his G35, then he had them on a 2013 genesis. Will they fit if the bore is off by .7? He said they were on a genesis????
je13 is offline
post #5074 of 6302 Old 01-25-2015
je13's Avatar
Quoted: 56 Post(s)
This was going to drive me crazy, so i did a test fit - they fit perfectly fine!
Good convo with myself there lol
je13 is offline
post #5075 of 6302 Old 01-26-2015
GEEZISS Coupe
4-AGE's Avatar
I'm definitely not looking for poke or camber. Just want a simple flush fitment, the front looks good to me too but the rear definitely needs a spacer.
The previous owner of these wheels had a 25 on and had some serious poke, like I said.
Do you think a 15 would be too mild of a spacer?
Unfortunately you can't solely use the information from the previous owner of the wheels to fit these on your own car. There are variables such as camber that take into play on how flush you want your wheels to be.
If I were to eyeball your pictures, I'm gonna throw a guess of 20mm. If you want to be correct, calculate and measure what you want.
4-AGE is offline
post #5076 of 6302 Old 01-26-2015
"Bentley" Owner
Copp3rhead's Avatar
Quoted: 88 Post(s)
Ended up doing my own research and found that Niche only made the front non concave 20x9's in +35 and +25. I grabbed some pictures of the wheels current state and think I've got +25 fronts and +40 rears now (they only make 20x10 in +40).
I have pictures I'll post later.
EDIT: Pictures...
Front:
Rear:
Mods
- BTR Canned Tune
- Brembo Brake Swap
- R1 Slotted Rotors
- LSD
- ARK H-Pipe
- DD HIDs (6000K)
- DD Stage 3 Fogs
- Tints (20%)
- BBM Lip Spoiler
post #5077 of 6302 Old 01-26-2015
POV Futografee
Tilley's Avatar
Quoted: 36 Post(s)
^If you've got a 20x9 +25 in the front, then you MAY only need a 5mm slip on spacer to clear those coils you're getting. (I ran a 9" +25 on the front with OEM struts and sportline springs with no issues) If you put that 15mm spacer on up front, that's probably going to be more aggressive than you want
Tilley is offline
post #5078 of 6302 Old 01-26-2015
"Bentley" Owner
Copp3rhead's Avatar
Quoted: 88 Post(s)
After confirming the +25 offset up front I'll be doing a 5/20 spacer setup for flush fitment.
The 5mm spacer should clear the ISC coils (same coils as HSD just different brand), at least that's the goal here.
I was told I will need camber bolts for up front for the install, is that correct?
Mods
- BTR Canned Tune
- Brembo Brake Swap
- R1 Slotted Rotors
- LSD
- ARK H-Pipe
- DD HIDs (6000K)
- DD Stage 3 Fogs
- Tints (20%)
- BBM Lip Spoiler
post #5079 of 6302 Old 01-26-2015
Quoted: 10 Post(s)
Can you fit a 19x10 in the front?
chambers102 is offline
post #5080 of 6302 Old 01-26-2015
POV Futografee
Tilley's Avatar
Quoted: 36 Post(s)
"NEED"... probably not. I'm assuming that you're not wanting to adjust camber outside the OEM specs though
Tilley is offline
The 2011 GC's are here! DSV-UltraGL General Discussion 738 01-07-2011 12:48 PM
Wheel fitment test on Genesis Coupe Track bestint California 11 11-02-2010 01:22 PM
Official Genesis Coupe DIY thread mack-attack General Discussion 3 06-02-2010 06:46 AM
Hyundai genesis coupe takes digital form in “forza motorsport 3” exclusively on xbox Mr.K Media 26 11-17-2009 05:58 PM
Finally Hyundai Coupe Release ! ER101160 General Discussion 40 12-21-2008 05:22 PM
Melbu1989
