Official Genesis Coupe Wheel Fitment Thread - Page 310 - Hyundai Genesis Forum
 159Likes
post #6181 of 6302 Old 04-27-2018
yungblud's Avatar
Quoted: 26 Post(s)
So hereís an update on the XXR 530D wheels for those interested in the fitment and how they look. Got 3 out of the 4 delivered today and all three had dings and gouges. So itíll be an even longer wait to get a look at them on the car. Obviously distributors have started shipping them, so if anyone has theirs now and can post pix, Iíd love to see them.
2016 Genesis Coupe 3.8
yungblud is offline
post #6182 of 6302 Old 04-28-2018
Car Nut
20" fitment
Hello,
I have a 2012 track edition with 19's + brembo's and since I will need new tires on the car, I am leaning towards buying 20's. Looking for a sanity check on these wheels offset and fitment. I am not looking for any poking out, rolling fenders, or stretched tire look, but like the deep dish look.
20x8.5 ET20 - 255/35/20
20x10 ET20 - 275/35/20
Thanks!
fiily K is offline
post #6183 of 6302 Old 04-28-2018
IG: jasonlikedthis
mrGainZ's Avatar
Quoted: 247 Post(s)
Originally Posted by fiily K View Post
Hello,
Thanks!
245/35 and 275/30.
2014 Tsukuba Red 2.0T AT
SFR Stage 1.5 Tune
Injen SRI
Synapse Radial BOV
ISR Race CBE / TP / DP
Khartunerz CF Lower Grill
Boostec CF Lip
Carbon Creations CF Trunk
VIS VIP CF Diffuser
BC Racing Coilovers
mrGainZ is offline
post #6184 of 6302 Old 04-28-2018
Car Nut
Originally Posted by mrGainZ View Post
245/35 and 275/30.
Sounds good. No poking out correct? Just want to make sure.
Thanks again
fiily K is offline
post #6185 of 6302 Old 04-29-2018
IG: jasonlikedthis
mrGainZ's Avatar
Quoted: 247 Post(s)
Thanks again
According to the chart, you should be flush.
SFR Stage 1.5 Tune
Injen SRI
Synapse Radial BOV
Boostec CF Lip
VIS VIP CF Diffuser
BC Racing Coilovers
mrGainZ is offline
post #6186 of 6302 Old 05-08-2018
I'm buying Avant Garde m510 rims -19 x 9.5 R, 19 x 8.5 F - on 275/35 and 245/35 tires. Will be putting them on HSD coilovers
I'll be able to get a custom offset with the order, so would really appreciate advice on what offset I should get for a nice flush look.
Let me know! Thanks!
amir_mek is offline
post #6187 of 6302 Old 05-09-2018
IG: jasonlikedthis
mrGainZ's Avatar
Quoted: 247 Post(s)
SFR Stage 1.5 Tune
Injen SRI
Synapse Radial BOV
Boostec CF Lip
VIS VIP CF Diffuser
BC Racing Coilovers
mrGainZ is offline
post #6188 of 6302 Old 05-09-2018
omphaloskeptic
Heywood's Avatar
Quoted: 10 Post(s)
I have the same sizes with +33 on the front and +25 on the rear. The rear is exactly what I wanted. The fronts are a little tucked. For me, a +25 offset there would be about right so I am considering 10mm spacers. Stock 4x4 height (for now). Michelin PS4's.
o~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~o
"Calling upon my years of experience, I froze at the controls." Sir Stirling Moss
Heywood is offline
post #6189 of 6302 Old 05-09-2018
Thanks for sharing, your fit looks good.
I'm a bit confused, since according to the chart the ideal offset is stated at +9 for both front and rear with 19s wit 8.5F and 9.5R , whereas you have a different offset with same rim size and your fitment looks flush
amir_mek is offline
post #6190 of 6302 Old 05-09-2018
omphaloskeptic
Heywood's Avatar
Quoted: 10 Post(s)
Yea, not sure about the difference with the chart. There is plenty of discussion about that in the hundreds of pages of this thread. LOL. I crunched the numbers and also used several on-line fit calculators to build confidence before pulling the trigger...
Heywood is offline
post #6191 of 6302 Old 05-09-2018
Thanks a lot! Yeah seems like your numbers match with what other folks have said with same size rims.
I hope there's clearance room for HSD coilovers... I heard they require more room than other coilovers, not sure if I should account for that somehow.... wish this was easier.
amir_mek is offline
post #6192 of 6302 Old 05-09-2018
Originally Posted by killer b6393 View Post
I am stuck on what my fronts should be. I originally wanted the following specs with HSD Coils but concerned that the extra 5mm clearance wont fit. I was going to go with:
Front
19x8.5 ET 25
Rear
19x9.5 ET 25
Would the front wheels clear the strut assembly from the HSD coilovers? if they don't fit would dropping to ET 20 in the front be the best solution?
Hey Killer_b6393 - Were you able to figure out if +25mm offset on the 8.5 & 9.5 19s would give the HSD coilovers enough room? I'm in exact situation as you.
amir_mek is offline
post #6193 of 6302 Old 05-21-2018
I'm in the process of purchasing Niche - M131 wheels for my Bk2 2.0t.
The specs for the Niche's are:
Front: 19x8.5 with a 25mm offset.
Rear: 19x10, 25mm offset.
I'm not entirely sure which tires I plan on running. I'm looking for a minimal stretch.
Would this setup work?
Front: 235/35/R19 or 245/35/R19
Rear: 265/35/R19 or 275/35 or 30/R19
Ultimately this is what I'm looking for all the way around.
http://i36.photobucket.com/albums/e3...psxgodnsjx.jpg
Thank-you!
Uchmanowicz is offline
post #6194 of 6302 Old 05-26-2018
I'm a bit late in asking this but I ordered a set of wheels and I'm not sure if they're going to rub the struts. If someone could let me know if I need wheel spacers and what size I'd appreciate it.
9.5x18 +40 (255/40/18) front
10.5x18 + 40 (275/40/18) rear
Hoondai is offline
post #6195 of 6302 Old 05-28-2018
IG: jasonlikedthis
mrGainZ's Avatar
Quoted: 247 Post(s)
Those are some pretty high offsets my friend. 15mm spacers all around should do the trick.
Hoondai likes this.
SFR Stage 1.5 Tune
Injen SRI
Synapse Radial BOV
Boostec CF Lip
VIS VIP CF Diffuser
BC Racing Coilovers
mrGainZ is offline
post #6196 of 6302 Old 05-29-2018
killer b6393's Avatar
Quoted: 15 Post(s)
yea the rears are 100% okay, however I put a 5mm spacer on the front because you still need like 2mm of clearance
2015 3.8 Ultimate, 6 M/T, Empire State Grey
Ark H-Pipe
Ark Grip Catback
Retrofitted headlights & fogs
35% tint
killer b6393 is offline
post #6197 of 6302 Old 06-07-2018
yungblud's Avatar
Quoted: 26 Post(s)
Gave up on the XXR 530Dís after shipping issues. Got ESR RF1s instead. I followed the sizing chart at the top of the thread, but I have rubbing issues. Got 19x9.5 +22 front and 19x10.5 +22 rear. Tires are 255/40 front and 285/45 rear. I know I got meatier tires that most would, but thatís my preference. Stance is aggressive, and I like it, but my front tires are rubbing on that base plate holding the stock coil in place. Idk what the correct term for it is, but its unnecessarily large and only seems to have been made that big to piss me off. Canít confirm this yet, but seeing as I only had about a quarter inch of clearance while on the jack, Im pretty sure itís that base plate . But it only seems to rub when cornering hard or hitting bumps during turns. The plate is pretty sharp, so I need a solution before it cuts into the tire. Anyone else have this issue? Any remedies? Unsure if I can somehow adjust the plate and compress the coil more to get more room, or if I can shave away a half inch or so without jeopardizing the integrity of the suspension. Also, the rear rubs, but Iím almost positive itís hitting the fender. Havenít put enough miles on them yet to be able to tell.
yungblud is offline
post #6198 of 6302 Old 06-14-2018
That did it for the rear, but not quite right for the front. The lip of the front rims are rubbing against the shocks when turning the wheel hard right. Ordered a set of 3mm spacer disks to add for a total of 18mm on the front. I also had to cut the lugs on the front about 5mm down so the wheel would sit flat on the spacer.
So just to clarify for anyone thinking of getting Miro 111 wheels,
Needs 15mm spacers on the back and at least 17mm on the front.
Hoondai is offline
post #6199 of 6302 Old 06-19-2018
I'd like to know if a set of wheels with +35 offset would be fine on a 2011 GT 3.8.
Fronts
19" DIAMETER (19" x 8.5")
[+35 Offset, 5x114.3 Bolt Pattern, 72.6mm Hub]
Rears
19" DIAMETER (19" x 9.5")
Any info is appreciated!
Unit 00 is offline
post #6200 of 6302 Old 06-20-2018
IG: jasonlikedthis
mrGainZ's Avatar
Quoted: 247 Post(s)
Fronts
Rears
Possibly, but wouldn't risk it. Looks like HeyWood above runs a 19x8.5 +33 in the fronts just fine, but he runs a lower offset in the rears. Worst case scenario run spacers or find wheels with offsets closer to +20 range.
Unit 00 likes this.
SFR Stage 1.5 Tune
Injen SRI
Synapse Radial BOV
Boostec CF Lip
VIS VIP CF Diffuser
BC Racing Coilovers
mrGainZ is offline
The 2011 GC's are here! DSV-UltraGL General Discussion 738 01-07-2011 12:48 PM
Wheel fitment test on Genesis Coupe Track bestint California 11 11-02-2010 01:22 PM
Official Genesis Coupe DIY thread mack-attack General Discussion 3 06-02-2010 06:46 AM
Hyundai genesis coupe takes digital form in ďforza motorsport 3Ē exclusively on xbox Mr.K Media 26 11-17-2009 05:58 PM
Finally Hyundai Coupe Release ! ER101160 General Discussion 40 12-21-2008 05:22 PM
Melbu1989
